The CyberPower’s BPSE72V45ART2U Battery Pack significantly extends runtime during power outages for Smart App Online S 2K/3K RT models.
The BPSE72V45ART2U external battery pack houses twelve (12) 12V 9Ah batteries, connected serially in two (2) strings of six (6) batteries. It is designed to match the appearance of the Smart App Online S UPS RT models and can be similarly mounted in 2U rack or tower configurations.
For OLS2000ERT2U/ OLS3000ERT2U models, up to 2 battery packs can be daisy-chained to the UPS for extended runtimes; for OLS2000ERTXL2U / OLS3000ERTXL2U, the external battery packs can be added up to 10 for your maximum flexibility.
Features & Benefits:
- Form Factor – 2U configuration supports both rack and tower mounting.
- On-board Replaceable Fuse Cover-Replaceable fuse is accessible from the rear panel. Must be done by qualified personnel.
- CyberPower Online S Series - UPS battery string - Lead Acid - 7 Ah
- Rack Size
- 2U
- 34.7 kg
- Battery
- Lead Acid - 7 Ah
- Battery Form Factor
- Rack-mountable
- Batteries Qty
- 12
- 43.8 cm x 43 cm x 8.8 cm
- 2 years warranty
- Battery Enclosure Type
- Rack-mountable
- Height (Rack Units)
- 2U
- Max Electric Current
- 45 A
- Quantity
- 12
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7 Ah
- Maintenance free, sealed
- Rugged
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- 43.8 cm
- 43 cm
- 8.8 cm
- 34.7 kg
