Product
CyberPower BPL48V75ART2U Battery Enclosure Lead Acid 9 Ah
Quicklinx: C1C1WS00 Mfr#: BPL48V75ART2U
The BPL48V75ART2U external battery pack houses twelve 12V 9Ah batteries, connected serially in two strings of six batteries. It is designed to match the appearance of the Smart App Online UPS models and can be similarly mounted in 2U rack or tower configurations. A battery data link transmits the unit's diagnostic vitals to the UPS display for real-time monitoring and a heavy gauge power cord, adapted with plug-n-play DC connectors, permits the battery pack to be easily "hot-swapped", ensuring continuous operation of critical systems, during normal UPS maintenance. Rugged, industrial-grade metal construction - meeting the same standards as the UPS models - allows for installation of the unit in demanding environments.
CyberPower BPL48V75ART2U - battery enclosure - Lead Acid - 9 Ah
Battery enclosure - external
Rack Size
2U
45.3 kg
Output Voltage
48 V
Lead Acid - 9 Ah
Battery Form Factor
Internal
Batteries Qty
12
Microsoft Windows 2000 Server, Microsoft Windows 2000/XP/Vista/7
43.2 cm x 60 cm x 8.9 cm
2 years warranty
Smart App Sinewave PR3000LCDRTXL2U, PR5000LCDRTXL5U, PR6000LCDRTXL5U
Battery Enclosure Type
Internal
Height (Rack Units)
2U
Output Voltage
48 V
Circuit Protection
Circuit breaker
Quantity
12
Lead Acid
Voltage Provided
12 V
9 Ah
Recharge Time
8 hours
Spill-proof
FCC Class B certified, cUL, DOC-B, UL 1778, RoHS
0 - 95%
43.2 cm
60 cm
8.9 cm
45.3 kg
Shipping Width
55.3 cm
Shipping Depth
78.2 cm
Shipping Height
28 cm
Shipping Weight
57 kg
CyberPower Smart App Sinewave PR3000LCDRTXL2U, PR5000LCDRTXL5U, PR6000LCDRTXL5U
