These 2U packs esthetically match the UPS, and can similarly be rack or tower mounted. The heavy gauge power cord is adapted with plug-n-play DC connectors for easy installation. The all metal enclosure safely houses the 8 (eight) 12V 9Ah batteries which are connected via 3 strings of 4 in series.
Form factor
2U configuration supports both rack and tower mounting. -
Metal housing
Rigid metal construction allows for placement in areas with a demanding environment. -
Power on/off switch
Local power switch is designed for manual reset and control. -
Back-panel fuse
User replaceable fuse is easily accessed from the rear panel.
- CyberPower BPE48V75ART2U - battery enclosure - Lead Acid - 9 Ah
- Battery enclosure - external
- Rack Size
- 2U
- 35 kg
- Battery
- Lead Acid - 9 Ah
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 8
- 43.3 cm x 48 cm x 8.8 cm
- Designed For
- Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 2U
- Circuit Protection
- Fuse
- Quantity
- 8
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Recharge Time
- 8 hours
- Rack Mounting Kit
- Included
- RoHS
- 0 °C
- 40 °C
- 0 - 95%
- 43.3 cm
- 48 cm
- 8.8 cm
- 35 kg
- Designed For
- CyberPower Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
