CyberPower BPE48V75ART2U Battery Enclosure Lead Acid 9 Ah
Quicklinx: C1C0WS00 Mfr#: BPE48V75ART2U
These 2U packs esthetically match the UPS, and can similarly be rack or tower mounted. The heavy gauge power cord is adapted with plug-n-play DC connectors for easy installation. The all metal enclosure safely houses the 8 (eight) 12V 9Ah batteries which are connected via 3 strings of 4 in series.
  • Form factor
    2U configuration supports both rack and tower mounting.
  • Metal housing
    Rigid metal construction allows for placement in areas with a demanding environment.
  • Power on/off switch
    Local power switch is designed for manual reset and control.
  • Back-panel fuse
    User replaceable fuse is easily accessed from the rear panel.
CyberPower BPE48V75ART2U - battery enclosure - Lead Acid - 9 Ah
Battery enclosure - external
Rack Size
2U
35 kg
Lead Acid - 9 Ah
Battery Form Factor
Plug-in module
Batteries Qty
8
43.3 cm x 48 cm x 8.8 cm
Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Circuit Protection
Fuse
Quantity
8
Lead Acid
Voltage Provided
12 V
9 Ah
Recharge Time
8 hours
Rack Mounting Kit
Included
RoHS
0 - 95%
43.3 cm
48 cm
8.8 cm
35 kg
CyberPower Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
