Cyberpower 8-Way 1U Horizontal Rackmount PDU w/ Management - C13 to C20
Quicklinx: 9X7LWS00 Mfr#: PDU20SWHVIEC8FNET
The CyberPower (PDU20SWHVIEC8FNET) 8-outlet 1U rack mount switched power distribution unit (PDU) provides 200-240V 20A output. It distributes power to 8 IEC-320 C13 receptacles from a single IEC-320 C20 plug, with unfiltered electrical pass-through. Outlets can be managed individually over the network, using CyberPower Management Console and the RJ45 Ethernet port for local network connection, or locally using the LCD. The LCD displays the electrical current of connected equipment in amps and can be toggled to display input voltage, power being consumed in watts, and the PDU's IP address. The CyberPower Management Console offers remote management of the unit: monitoring PDU vitals as well as controlling outlets and networked clients.
This unit has a rugged, industrial-grade metal housing and a 10-foot AC power cord. It can be mounted horizontally or vertically, includes a cord retention tray and is UL60950 1 & FCC Class A certified.
CyberPower Switched Series PDU20SWHVIEC8FNET - power distribution unit
Power distribution unit - rack-mountable
Input Voltage
AC 200-240 V
Output Voltage
AC 200-240 V
Input Connectors
Power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Ethernet, RS-232
Remote Management Protocol
SNMP, HTTP
43.3 cm x 11.2 cm x 4.4 cm
Input Voltage
AC 200-240 V
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C20
Output Voltage
AC 200-240 V
Max Electric Current
20 A
Remote Management Interface
Ethernet, RS-232
SNMP, HTTP
1 x LAN - RJ-45 , 1 x RS-232
Power cable 3 m
Digital voltmeter, amp meter, overload protection, digital power meter
FCC Class A certified, CSA C22.2, RoHS, UL 60950-1
45 °C
0 - 95% (non-condensing)
43.3 cm
11.2 cm
4.4 cm
