The CyberPower 12-outlet rack mount basic power distribution unit (PDU20BHVIEC12R) provides 208V/230V 20A output. It distributes power to 12 IEC-320 C13 receptacles from a single IEC-320 C20 plug, with unfiltered electrical pass-through. Designed for datacenters and other electrically demanding applications, this unit has a rugged, industrial-grade metal housing and a 10-foot AC power cord.
- CyberPower Basic Series PDU20BHVIEC12R - power distribution unit
- Power distribution unit - rack-mountable
- Rack Size
- 1U
- 0.9 kg
- Input Voltage
- AC 200/230 V
- Output Voltage
- AC 200/230 V
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 12 x power IEC 60320 C13
- 44.5 cm x 3.8 cm x 4.5 cm
- 2-year warranty
- Height (Rack Units)
- 1U
- Input Voltage
- AC 200/230 V
- Input Voltage Range
- AC 200 - 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200/230 V
- Max Electric Current
- 20 A
- Circuit Protection
- Circuit breaker
- Cables Included
- Power cable 3 m
- Rack Mounting Kit
- Included
- Rugged, overload protection, vertical orientation
- CSA C22.2, RoHS, ETL, UL 60950-1
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 44.5 cm
- 3.8 cm
- 4.5 cm
- 0.9 kg
- Shipping Width
- 53 cm
- Shipping Depth
- 33 cm
- Shipping Height
- 23.3 cm
- Shipping Weight
- 2.4 kg
