CTOUCH Leddura 86" 3840x2160 4K LEDLarge Format Display
Quicklinx: D925WS00 Mfr#: 10051986
TV Tuner Presence: No
Video Interface: Composite, HDMI
£23,050.59 ex VAT
£27,660.70 inc VAT
Leddura 2Meet is developed to make collaboration more accessible and more interactive in any meeting room. Everything you need for an effective meeting comes together in one system: wireless content sharing, whiteboarding, video conferencing, and direct insight into the availability of meeting rooms. Get to know the ideal solution for agile and lean teams.
  • Wireless content sharing from any device
    Share your content wirelessly and bring interaction to your team. If you are using iPhones, Android, Mac or PC, you can now easily display 4 devices on the touchscreen at the same time. All in a secure and reliable environment.
  • Whiteboarding: make notes directly on the screen
    Simply start the whiteboarding feature with one press of the button. Everyone in the meeting can simultaneously write, annotate, share files and add new pages.
  • Ideal match for video conferencing
    The Leddura 2Meet touchscreen is specifically designed to integrate seamlessly with Skype for Business. This makes using this touchscreen easy and trustworthy. The touch functionality allows simple and interactive editing of documents and content during meetings. Whether you want to call with Skype for Business users, H323 devices, or phone numbers: video conferencing with colleagues around the world has never been so easy.
  • Room booking: easily make a reservation and get direct insight into availability
    Schedule a meeting in Outlook, then go to the meeting room and start the meeting with 1 press of the button. Is there a meeting room free? You can also easily make a reservation from the screen. Did you forget to cancel a meeting? No problem, if the room is not being used, Leddura 2Meet will release it automatically after 15 minutes.
CTOUCH Leddura 2Meet 86" Class (85.6" viewable) LED display - 4K
LED-backlit LCD flat panel display with built-in interactive whiteboard, touchscreen (multi touch)
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Sound Effects
JBL Live Stage
USB
2 ports
Remote Control
Standard remote
Energy Class
Class A+
214 Watt
Power Consumption (On mode)
214 W
Energy Consumption per Year
312 kWh
199.36 cm x 12.6 cm x 117.76 cm
112 kg
3-year warranty
Energy Class
Class A+
214 Watt
214 W
312 kWh
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Yes - interactive
Combined With
Built-in interactive whiteboard, touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Backlight off mode, Dynamic Picture Mode, user mode, soft mode, Standard mode
Dimensions
Without stand
199.36 cm
12.6 cm
117.76 cm
112 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight - direct-lit LED - direct-lit LED
Coating
Anti-reflection
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Touchpoints Qty
32
Display Menu Language
English
Open Pluggable Specification slot, integrated whiteboard functions, 10-bit Video Processing, Surface Light Wave, built-in Wi-Fi router
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Surround Mode
Sound Effects
JBL Live Stage
Speaker System
2 speakers
Output Power / Total
80 Watt
Echo cancellation, JBL 3-way sound system, JBL Far Field microphone
Speakers
2 x speaker - built-in - 40 Watt
Driver Details
Speaker: tweeter driver , Speaker: mid-range driver , Speaker: woofer driver
Network & Internet Multimedia
Functionality
Whiteboard
Wi-Fi, LAN
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
Connector Type
2 x HDMI input , DisplayPort input , 3 x VGA input , VGA output , Composite video/audio input , 3 x audio line-in , SPDIF output , 2 x USB 2.0 , USB , RS-232C , LAN , HDMI output
Docking station, electronic touch pen, visitor USB tokens
USB cable ¦ HDMI cable
Plug and Play, ISO 9001, ISO 14001, RoHS, HDCP 2.2
Power supply
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years
Width (Shipping)
211.4 cm
Depth (Shipping)
29 cm
Height (Shipping)
145.6 cm
Weight (Shipping)
128 kg
Video Interface: HDMI
Brand: CTOUCH
Price Range Ex VAT: 1500+
