Get everyone connected through touch! Make a dazzling first impression, interact with your audience. What you see is the flawless presentation of the facts.
- CTOUCH Leddura 2Share - 75" Class (74.5" viewable) LED-backlit LCD display - 4K
- Product Type
- LED-backlit LCD flat panel display with built-in interactive whiteboard, touchscreen (multi touch)
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- Sound Effects
- JBL Live Stage
- USB
- 2 ports
- Included Accessories
- Remote control, docking station, electronic touch pen, visitor USB tokens
- Energy Class
- Class A+
- Power Consumption (On mode)
- 163 W
- Energy Consumption per Year
- 237 kWh
- Dimensions (WxDxH) - without stand
- 173.56 cm x 12.2 cm x 102.76 cm
- 86 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A+
- 163 W
- 237 kWh
- Diagonal Class
- 75"
- Diagonal Size
- 74.5"
- Combined With
- Built-in interactive whiteboard, touchscreen (multi touch)
- Series
- 2Share
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Backlight off mode, Dynamic Picture Mode, user mode, soft mode, Standard mode
- Dimensions
- Without stand
- 173.56 cm
- 12.2 cm
- 102.76 cm
- 86 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- Anti-reflection
- Image Contrast Ratio
- 1200:1
- Brightness
- 350 cd/m²
- Touchpoints Qty
- 32
- Display Menu Language
- English
- Open Pluggable Specification slot, integrated whiteboard functions, 10-bit Video Processing, Surface Light Wave, built-in Wi-Fi router, live quad picture view
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- JBL Live Stage
- Speaker System
- 2 speakers
- Output Power / Total
- 80 Watt
- Echo cancellation, JBL 3-way sound system, JBL Far Field microphone, Voice Logic technology, Sonique technology, advanced ambient noise reduction
- Speakers
- 2 x speaker - 40 Watt
- Driver Details
- Speaker: tweeter driver , Speaker: mid-range driver , Speaker: woofer driver
Network & Internet Multimedia
- Functionality
- Whiteboard
- Connectivity
- Wi-Fi, LAN
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Connector Type
- 2 x HDMI input , DisplayPort input , 3 x VGA input , VGA output , Composite video/audio input , 3 x audio line-in , SPDIF output , USB 2.0 , USB , RS-232C , LAN , Headphones , HDMI output , Microphone , USB
- Docking station, electronic touch pen, visitor USB tokens
- Cables Included
- USB cable , HDMI cable
- ISO 9001, ISO 14001, RoHS, HDCP 2.2
- Power Device
- Power supply
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years
- Width (Shipping)
- 187.1 cm
- Depth (Shipping)
- 25 cm
- Height (Shipping)
- 116.3 cm
- Weight (Shipping)
- 96 kg
