Product
CTOUCH Laser air+ 65" UHD 4K LED display
Quicklinx: D037WS00 Mfr#: S10150627
The CTOUCH Laser air+ is a masterpiece when it comes to craftsmanship, technology and making touch accessible to the world. Integrating innovations like uWand, Beacon receivers and JBL sound, opening a complete new and unique experience in touch.
  • 32 point Surface Light Wave™ - use 32 fingers at the same time
  • COS™ - CTOUCH Android operating system
  • CTOUCH app store - get instant access to high rated apps
  • Built in Wi-Fi router
  • CTOUCH Easy air PC module ready for flexible and heavy duty power
  • Versatile annotation app - annotate over any software
  • Best service & support - 7 years!
  • JBL 80 watts speakers - designed, tuned and built by HARMAN
  • uWand interactive gesture remote - touch your display at 5 meters distance
  • Low power consumption. Green energy label B.
ENHANCE INTERACTIVE TECHNOLOGY
Discover the freedom of connecting up to 4 devices simultaneously with full touch capability, thanks to the 10 touch points. Adaptive screen brightness ensures a clear, razor-sharp picture with energy saving Ambient light sensor. Saving energy and money at once.
INCREASE EFFECTIVE GROUP WORKING
Built-in PC on Android 5.0 with 16MB ROM allows you to access and work with apps at any moment. Create your own network and manage your own bandwidth with the integrated WiFi router. The CTOUCH Laser air+ has instant video and is pre configured to enable instant Skype calls.
STIMULATE SHARING OF KNOWLEDGE
Discover CTOUCH Operating System (COSTM), our custom built CTOUCH user interface that gives you easy, user-friendly access in order to maximize your touch experience. Get instant access to over 600.000 high rated apps, ready for you to download in the CTOUCH Apps store, With the annotation app you now have one versatile tool to write over any software.
BEST IN CLASS QUALITY PRODUCTS AND SERVICES
Enjoy the room-filling experience of the 80 Watts JBL 2.1 sound system with integrated speakers, designed, tuned and built by HARMAN. The light wave technology enables you to have a natural touch experience with the speed of light, smooth touch detection and maximal reach. 7 years warranty.
SOFTWARE
Get the most out of your CTOUCH Laser Air by combining it with the best professional software on the market.
SOUND
Take a moment to listen to the sound of perfection. The beautiful bond between sound and vision makes the CTOUCH experience even more unforgettable. Discover the JBL Audio System; an amazing JBL-designed speaker system that creates true JBL high-quality sounds, and discover a whole new environment for business and educational presentations.
Touch system
Touch system: Surface Light Wave
Touch points: 32 points
Touch tool: Hand or other solid (soft tip) object
Accuracy: ± 3 mm
Read speed: 150 responses per second
Response time: 6.6 ms
Effective screen size (mm): 1209.6(H) × 680.4(V)
Interface: USB 1.1 compatible (full speed) HID compliant, Plug & Play compatible, USB 2.0
Supported OS: Windows, Mac and Android
Touch driver: Not required for 20 points (under Windows and Android); 32 points need driver (under Windows)
Panel
Diagonal size: 65‘‘
Panel resolution: 3840 x 2160
Recommended resolution: 3840 x 2160
Brightness (Nits): 350 cd/m2
Contrast ratio: 4000 : 1
Response time: 8 ms
Aspect ratio: 16 : 9
Display colors: 1.07 Billion colours (10-bit)
Pixel pitch (mm): 0.372(W) × 0.372(H)
Back light unit: Direct type LED
Anti reflective glass: Yes
Video input (digital): HDMI x 2, DP x 1, USB 2.0 x 1, USB 3.0 x 2
Video input (analogue): VGA IN x 3, VGA OUT x 1,AV IN (mini jack) x 1
Audio input: x 3
Audio output: x 1(SPDIF)
USB (for touch): x 2
uWAND sensor beacon: Yes
Network controllable input: RS232C, LAN IN
VIDEO
PSM: Warm / Cool / Normal
Picture mode: Dynamic / Standard / Soft / User
Freeze function: Yes
Backlight mute function: Yes
Ambient light sensor (auto adjust backlight): Yes
SOUND - Designed, tuned and built by HARMAN
Transducers: Stereo JBL 3-Way Speakers (tweeter, mid-range and woofer)
SOUND
Amplifier power: 80 watts
frequency range: 60Hz – 20kHz
THD @ 1W: 15% Max, 60Hz~250Hz (Woofer L/R)
5% Max, 250Hz~10kHz (Mid & TW L/R)
FUNCTION
Touch OSD: Via home button: Yes
Languages: English
Internal CTOUCH Easy air PC module slot: Yes
uWAND interactive gesture remote: Yes
Dimensions and Quality Approvals
Dimensions (mm): 1513.6(W) x 901.6(H) x 116(D)
Product weight: 52 kg
VESA mount (mm): 400(W) x 400(H)
Green approvals: RoHS compliant
Regulatory approvals: CE
ISO standard: ISO9001 and ISO14001
Thickness of safety glass: 5 mm
Total cost of ownership
Service & warranty: 7 years warranty
Power consumption nominal: 189W
Power consumption sleep mode: < 3W
Product accessories- Included
Accessoires pack: Power cable, USB cable, HDMI cable, remote, touch pen, Quick start guide
Connection software: Shipped with one license
Multi touch annotation software: Shipped with one license
Gesture recognition: Yes, refer to CTOUCH manual
uWAND interactive gesture remote: Yes, special remote included
Android
System version: 5.0.1
CPU: ARM Cortex A53 1.5 GB (64Bit 4Core)
GPU: Mali-450
RAM: 2 GB
ROM: 16 GB
CONNECTIVITY
Easy air PC Module i3: 10052021
Easy air PC Module i5: 10052022
Easy air PC Module i7: 10052023
SOFTWARE
Oktopus: Included
MOUNTING
CTOUCH Wallom wall lift - electric: 10080201
CTOUCH WMT mobile lift - electric: 10080212
CTOUCH WMT tilt table - electric: 10080302
Logistics information
Box size (mm): 1637(W) x 1067(H) x 234(D) mm
Gross weight: 61 kg
EAN no.: 8718868301864
