The CTOUCH Laser air+ is a masterpiece when it comes to craftsmanship, technology and making touch accessible to the world. Integrating innovations like uWand, Beacon receivers and JBL sound, opening a complete new and unique experience in touch.
- 32 point Surface Light Wave™ - use 32 fingers at the same time
- COS™ - CTOUCH Android operating system
- CTOUCH app store - get instant access to high rated apps
- Built in Wi-Fi router
- CTOUCH Easy air PC module ready for flexible and heavy duty power
- Versatile annotation app - annotate over any software
- Best service & support - 7 years!
- JBL 80 watts speakers - designed, tuned and built by HARMAN
- uWand interactive gesture remote - touch your display at 5 meters distance
- Low power consumption. Green energy label B.
ENHANCE INTERACTIVE TECHNOLOGY
Discover the freedom of connecting up to 4 devices simultaneously with full touch capability, thanks to the 10 touch points. Adaptive screen brightness ensures a clear, razor-sharp picture with energy saving Ambient light sensor. Saving energy and money at once.
INCREASE EFFECTIVE GROUP WORKING
Built-in PC on Android 5.0 with 16MB ROM allows you to access and work with apps at any moment. Create your own network and manage your own bandwidth with the integrated WiFi router. The CTOUCH Laser air+ has instant video and is pre configured to enable instant Skype calls.
STIMULATE SHARING OF KNOWLEDGE
Discover CTOUCH Operating System (COSTM), our custom built CTOUCH user interface that gives you easy, user-friendly access in order to maximize your touch experience. Get instant access to over 600.000 high rated apps, ready for you to download in the CTOUCH Apps store, With the annotation app you now have one versatile tool to write over any software.
BEST IN CLASS QUALITY PRODUCTS AND SERVICES
Enjoy the room-filling experience of the 80 Watts JBL 2.1 sound system with integrated speakers, designed, tuned and built by HARMAN. The light wave technology enables you to have a natural touch experience with the speed of light, smooth touch detection and maximal reach. 7 years warranty.
SOFTWARE
Get the most out of your CTOUCH Laser Air by combining it with the best professional software on the market.
SOUND
Take a moment to listen to the sound of perfection. The beautiful bond between sound and vision makes the CTOUCH experience even more unforgettable. Discover the JBL Audio System; an amazing JBL-designed speaker system that creates true JBL high-quality sounds, and discover a whole new environment for business and educational presentations.
- Touch system
- Touch system: Active IR
- Touch points: 32 points
- Touch tool: Hand or other solid (soft tip) object
- Accuracy: ± 3 mm
- Read speed: 120 responses per second
- Response time: 9 ms
- Effective screen size (mm): 1895,04 (W) x 1065,7 (H)
- Interface: USB 1.1 compatible (full speed) HID compliant, Plug & Play compatible, USB 2.0
- Supported OS: Windows, Mac and Android
- Touch driver: Not required for 20 points (under Windows and Android); 32 points need driver (under Windows)
- Panel
- Diagonal size: 85,6”
- Panel resolution: 3840 x 2160
- Recommended resolution: 3840 x 2160
- Brightness (Nits): 350 cd/m2
- Contrast ratio: 1200 : 1
- Response time: 8 ms
- Aspect ratio: 16 : 9
- Display colour: 1.07 Billion colours (10-bit)
- Pixel pitch (mm): 0.4935 (W) × 0.4935 (H)
- Back light unit: Direct LED
- Anti reflective glass: Yes
- Connectivity
- Video input (digital): HDMI x 2, USB 2.0 x 4, USB 3.0 x 2, DP x 1
- Video input (analogue): VGA IN x 3, VGA OUT x 1, AV IN (mini jack) x 1
- Audio input: x 3
- Audio output: x 1 (SPDIF)
- USB (for touch): x 2
- uWAND sensor beacon: Yes
- Network controllable input: RS232C, LAN IN
- VIDEO
- PSM: Warm / Cool / Normal
- Picture mode: Dynamic / Standard / Soft / User
- Freeze function: Yes
- Backlight mute function: Yes
- Ambient light sensor (auto adjust backlight): Yes
- SOUND - Designed, tuned and built by HARMAN
- Transducers: 2 Stereo JBL 3-Way Speakers (tweeter, mid-range and woofer)
- Amplifier power: 80 watts
- frequency range: 60Hz - 20kHz
- FUNCTION
- Touch OSD: Via home button: Yes
- Languages: English
- Internal CTOUCH Easy air PC module slot: Yes
- uWAND interactive gesture remote: Yes
- HDCP compliance:: 2.2
- Dimensions and Quality approvals
- Dimensions (mm): 1993.6 (W) x 1177.6 (H) x 112 (D)
- Product weight: 112 kg
- VESA mount (mm): 600 (W) x 400 (H)
- Green approvals: RoHS compliant
- Regulatory approvals: CE
- ISO standard: ISO9001 and ISO14001
- Thickness of safety glass: 4 mm
- Total cost of ownership
- Service & warranty: 7 years warranty
- Power consumption sleep mode: 0.5 W
- Product accessories- Included
- Accessoires pack: Power cable, USB cable, HDMI cable, remote, touch pen, Quick start guide
- Annotation: Yes, annotate over any software application
- Gesture recognition: Yes, refer to CTOUCH manual
- uWAND interactive gesture remote: Yes, special remote included
- Android
- System version: 5.0.1
- CPU: ARM Cortex A53 1.5 GB (64 Bit 4 Core)
- GPU: Mali-450
- RAM: 2 GB
- ROM: 16 GB
- CONNECTIVITY
- Easy air PC Module i3: 10052021
- Easy air PC Module i5: 10052022
- Easy air PC Module i7: 10052023
- MOUNTING
- CTOUCH Wallom wall lift - electric: 10080201
- CTOUCH WMT mobile lift - electric:
- Logistics information
- Box size (mm): 2114 (B) x 1456 (H) x 290 (D)
- Gross weight: 128 kg
- EAN no.: 8718868301994
