Room to spare
Securely load and store important files on Micron NAND in a tiny M.2 form factor. -
Vital performance
The NVMe PCIe technology delivers high sequential read/write speeds so you can hammer out your work and compete online faster than ever before. -
Lasting value
The Crucial P1 SSD is designed to be the only storage upgrade you'll need with an affordable blend of performance and capacity.
- Crucial P1 - solid state drive - 1 TB - PCI Express 3.0 x4 (NVMe)
- Solid state drive - internal - 3D NAND Technology, NVM Express (NVMe)
- Capacity
- 1 TB
- Form Factor
- M.2 2280
- Interface
- 22 mm x 80 mm
- 5-year warranty
- Capacity
- 1 TB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
Performance
- SSD Endurance
- 200 TB
- Internal Data Rate
- 2000 MBps (read) / 1700 MBps (write)
- 4KB Random Read
- 170000 IOPS
- 4KB Random Write
- 240000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Software Included
- Acronis True Image
- UL, TUV, VCCI, BSMI, FCC, RoHS, KCC, WEEE, ICES, halogen-free, China RoHS, RCM, Morocco
- Limited warranty - 5 years
- 0 °C
- 70 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
DWCZ 043584 Condition: Customer return - item has been opened but is in excellent condition |
£70.74 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
