Crucial P1 1TB NVMe M.2 SSD
Quicklinx: DWCZWS00 Mfr#: CT1000P1SSD8
Form Factor: M.2 2280
Capacity: 1TB, 1TB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
Stock Status: In Stock, Used Stock
Select:
3 in stock
£77.67 ex VAT
£93.20 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
  • Room to spare
    Securely load and store important files on Micron NAND in a tiny M.2 form factor.
  • Vital performance
    The NVMe PCIe technology delivers high sequential read/write speeds so you can hammer out your work and compete online faster than ever before.
  • Lasting value
    The Crucial P1 SSD is designed to be the only storage upgrade you'll need with an affordable blend of performance and capacity.
Crucial P1 - solid state drive - 1 TB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal - 3D NAND Technology, NVM Express (NVMe)
1 TB
M.2 2280
22 mm x 80 mm
5-year warranty
1 TB
M.2 2280
22 mm
80 mm
Performance
SSD Endurance
200 TB
Internal Data Rate
2000 MBps (read) / 1700 MBps (write)
4KB Random Read
170000 IOPS
4KB Random Write
240000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Software Included
Acronis True Image
UL, TUV, VCCI, BSMI, FCC, RoHS, KCC, WEEE, ICES, halogen-free, China RoHS, RCM, Morocco
Limited warranty - 5 years
70 °C
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DWCZ 043584
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £70.74
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Capacity: 1TB
Capacity: 1TB
Brand: Crucial
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
