Crucial Micron 9200 PRO 3.84TB NVMe U.2 Enterprise SSD
Quicklinx: DFFKWS00 Mfr#: MTFDHAL3T8TCT-1AR1ZABYY
Form Factor: 2.5" SFF
Capacity: 3.84TB
Interface: U.2 PCIe 3.0 (NVMe)
Type: Internal hard drive
Select:
£993.67 ex VAT
£1,192.40 inc VAT
Today's data deluge requires a revolutionary way to mine data for insights and turn insights into action. Created to radically accelerate data center applications and workloads, the Micron 9200 series of SSDs combines the capacity of 3D NAND with the proven throughput and response times of the NVM Express (NVMe) protocol to deliver one of the most complete high-capacity, high-performance solutions available. Maximize application throughput and minimize latencies to get faster access to your data - and a powerful business advantage. Available in the U.2 and HHHL form factors in capacities from 1.6TB to 11TB.
  • Accelerate your applications
    Accelerate the transformation of data into business value and provide a higher level of service to your customers with transfer speeds up to 5.5 GB/s and read IOPS up to 900K.
  • Large and in charge
    With capacities up to 11TB, the Micron 9200 SSD satisfies the most storage-hungry use cases in about one quarter of the rack space of 2D NAND.
  • Unlock the value of your data transfer
    Using the fastest of all SSD interfaces, the Micron 9200 family of high-performance NVMe drives accelerates applications on demanding workloads.
  • Optimize your existing infrastructure
    Deliver bottom-line value and efficiency to business and IT operations with Micron's high-performance flash solutions in industry-standard capacities up to 11TB.
  • Get peace of mind with solid data protection
    Ensure data integrity with the Micron 9200 SSD's full enterprise end-to-end data path protection, power-loss protection, and secure signed firmware.
Micron 9200 PRO - solid state drive - 3.84 TB - U.2 PCIe 3.0 (NVMe)
Solid state drive - internal - Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity
3.84 TB
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5" SFF
U.2 PCIe 3.0 (NVMe)
Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity, S.M.A.R.T.
69.85 mm x 100.5 mm x 15 mm
3.84 TB
2.5" SFF
U.2 PCIe 3.0 (NVMe)
Bytes per Sector
512
69.85 mm
100.5 mm
15 mm
Performance
SSD Endurance
7 PB
Internal Data Rate
3.35 GBps (read) / 2.4 GBps (write)
4KB Random Read
800000 IOPS
4KB Random Write
130000 IOPS
Expansion & Connectivity
Compatible Bay
2.5" SFF
Power Consumption
8 Watt (idle) , 25 Watt (active)
BSMI CNS 13438 Class B, EN55024, ICES-003 Class B, RoHS, UL 60950-1 Second Edition, AS/NZS CISPR22:2006 Class B, IEC60950/EN60950, WEEE 2012/19/EC, KCC KN32 Class B, KCC KN35, VCCI 2015.04 Class B
85 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
25 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
3.1 g @ 5-800 Hz
Capacity: 3.84TB
Brand: Crucial
Price Range Ex VAT: 750 - 1000
