Crucial Micron 9200 MAX 3.2TB NVMe U.2 Enterprise SSD
Quicklinx: DFFNWS00 Mfr#: MTFDHAL3T2TCU-1AR1ZABYY
Form Factor: 2.5" SFF
Capacity: 3.2TB
Interface: U.2 PCIe 3.0 (NVMe)
Type: Internal hard drive
Select:
£994.75 ex VAT
£1,193.70 inc VAT
Today's data deluge requires a revolutionary way to mine data for insights and turn insights into action. Created to radically accelerate data center applications and workloads, the Micron 9200 series of SSDs combines the capacity of 3D NAND with the proven throughput and response times of the NVM Express (NVMe) protocol to deliver one of the most complete high-capacity, high-performance solutions available. Maximize application throughput and minimize latencies to get faster access to your data - and a powerful business advantage. Available in the U.2 and HHHL form factors in capacities from 1.6TB to 11TB.
Micron 9200 MAX - solid state drive - 3.2 TB - U.2 PCIe 3.0 (NVMe)
Solid state drive - internal - Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity
3.2 TB
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5" SFF
U.2 PCIe 3.0 (NVMe)
Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity, S.M.A.R.T.
69.85 mm x 100.5 mm x 15 mm
3.2 TB
2.5" SFF
U.2 PCIe 3.0 (NVMe)
Bytes per Sector
512
69.85 mm
100.5 mm
15 mm
Performance
SSD Endurance
17.5 PB
Internal Data Rate
3.35 GBps (read) / 2.4 GBps (write)
4KB Random Read
800000 IOPS
4KB Random Write
255000 IOPS
Expansion & Connectivity
Compatible Bay
2.5" SFF
Power Consumption
8 Watt (idle) , 25 Watt (active)
BSMI CNS 13438 Class B, EN55024, ICES-003 Class B, RoHS, UL 60950-1 Second Edition, AS/NZS CISPR22:2006 Class B, IEC60950/EN60950, WEEE 2012/19/EC, KCC KN32 Class B, KCC KN35, VCCI 2015.04 Class B
85 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
25 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
3.1 g @ 5-800 Hz
Capacity: 3.2TB
Brand: Crucial
Price Range Ex VAT: 750 - 1000
