The 1100 SATA SSD provides exceptional performance and extremely low power consumption for client computing applications ranging from desktop gaming rigs to corporate road warrior tablets. The 1100 SSD is manufactured to excel in performance, endurance, price and power while enabling green computing. Device sleep (DEVSLP) low-power modes extend battery life, and several features protect valuable data, including Opal 2.0 self encryption, power-loss protection for data-at-rest and adaptive thermal monitoring.
Enhanced durability
With an MTBF of 1,500,000 hours, this solid state drive offers reliability and durability for users who demand performance over time. Its robust shock and vibration tolerance ensures your data remains safe even in non-operating conditions, making it an ideal choice for users who value data integrity. -
High-speed performance
Experience swift data transfer with internal data rates of up to 530 MBps for reading and 500 MBps for writing. Coupled with a 4KB random write of 83,000 IOPS, this drive is designed to handle intensive tasks efficiently, providing a seamless computing experience. -
Low power consumption
Featuring DEVSLP SATA low power mode, this solid state drive is engineered for efficiency. It reduces power consumption without sacrificing performance, making it an excellent choice for users looking to enhance their system's energy efficiency. -
Advanced compatibility
Microsoft eDrive compatible and equipped with a Serial ATA-600 interface, this drive offers versatile compatibility and easy integration into existing systems. Its adherence to several compliant standards including S.M.A.R.T. ensures a reliable and secure storage solution.
 - Micron 1100 - SSD - 256 GB - SATA 6Gb/s
 - Solid state drive - internal
- Capacity
 - 256 GB
- Hardware Encryption
- Encryption Algorithm
 - 256-bit AES
- NAND Flash Memory Type
 - 16nm 3D triple-level cell (TLC)
- Form Factor
 - M.2 2280
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
 - Native Command Queuing (NCQ), Device Initiated Power Management (DIPM), Secure Erase function, Adaptive thermal monitoring, DEVSLP SATA low power mode, Microsoft eDrive compatible, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, dynamic write acceleration, S.M.A.R.T.
 - 22 mm x 80 mm
- Capacity
 - 256 GB
 - 256-bit AES
- Form Factor
 - M.2 2280
- Interface
 - SATA 6Gb/s
- Bytes per Sector
 - 512
 - 22 mm
 - 80 mm
Performance
- SSD Endurance
 - 120 TB
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 530 MBps (read) / 500 MBps (write)
- 4KB Random Read
 - 55000 IOPS
- 4KB Random Write
 - 83000 IOPS
- Average Latency
 - 40 µs
Reliability
- MTBF
 - 1,500,000 hours
- Non-Recoverable Errors
 - 1 per 10^15
Expansion & Connectivity
 - 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
 - M.2 2280
- Power Consumption
 - 55 mW (idle) , 70 mW (active) , 2 mW (sleep) , 3000 mW (maximum)
 - TUV, RRL, ICES-003 Class B, IC, RoHS, UL 60950-1 Second Edition, KCC, WEEE, BSMI CNS 13438, FCC CFR47 Part 15 B, RCM, VCCI V-3/2011.04, Directive 2012/19/EC, OPAL 2.0, IEC60950/EN60950, IEEE 1667, KN32, KN35, EN 55032 Class B, ATA-8 ACS3, AS/NZS CISPR 32 Class B
 - 0 °C
 - 70 °C
 - 5 - 95% (non-condensing)
- Shock Tolerance (non-operating)
 - 1500 g @ 0.5 ms
- Vibration Tolerance (non-operating)
 - 3.1 g @ 5-800 Hz
