For memory-dependant server applications such as virtualization - cloud computing - Big Data - and HPC - Crucial DDR4 server memory is an ideal way to increase memory bandwidth and capacity.
High bandwidth
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial memory significantly increases memory bandwidth, allowing your system to handle more data at once. As memory technology matures, bandwidths are expected to achieve amazing speeds. To maximize bandwidth, Crucial memory is optimized for next-gen platforms, that support four channel memory. -
More energy efficient
Get better performance - using less power. Operating at lower power, Crucial memory consumes less voltage. Crucial modules also contain other efficiency features, for an outstanding overall power reduction.
- Crucial - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Dual rank, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- X8
- Voltage
- 1.2 V
- Colour Category
- Black, green
