n the ever-changing world of technology, any component more than five years old is usually in need of an update. At seven years old and counting, that's where DDR3 memory is at: laptops can only do so much with it. Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 SODIMMs, crush the DDR3 memory bottleneck and unlock a new standard of performance.
More density
Pack more memory into your laptop than ever before. Crucial memory debuts in large densities, and as the technology develops, modules are projected to be extremely fast. Since laptops only have 1-2 memory slots, high-density Crucial modules allow you to overcome this limitation and install more memory for faster mobile performance. -
More speed
Load applications faster and run demanding programs without lag. Crucial memory modules debut faster. -
More bandwidth
Effortlessly multitask between apps and empower your system to fire on all cylinders. Crucial modules increase memory bandwidth, allowing your system to handle more data at once. Crucial memory modules are optimized for next-gen platforms, allowing you to maximize bandwidth.
- Crucial - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Dual rank, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- X8
- Voltage
- 1.2 V
- Colour Category
- Black, green
