Crucial DDR4 8 GB DIMM 288-pin - 2400 MHz / PC4-19200
Quicklinx: CZXDWS00 Mfr#: CT8G4DFD824A
Marketing description is not available.
  • The fast, easy way to improve your desktop's performance
    There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Desktop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your desktop's multitasking capabilities.
  • Make everything on your computer faster
    Memory is a component in your computer that allows for short-term data access. Since your system's moment-to-moment operations rely on short-term data access- loading applications, browsing the Web or editing a spreadsheet - the speed and amount of memory in your system plays a critical role. Load apps in seconds by increasing the speed of your memory and installing more of it.
  • Multitask with ease
    You can use your computer to do a lot of things at once. You might be editing a document, while also looking at pictures and browsing the Internet. This naturally leads to a performance problem: every app you're running requires memory and competes for a limited pool of resources. Overcome this by installing high-density modules in each memory slot for seamless multitasking.
  • Maximize the value of your system
    At a fraction of the cost of a system, a memory upgrade is one of the most affordable ways to increase performance. Get more out of your desktop by giving it the resources it needs to perform.
Crucial - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Dual rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
