Your basket is empty
Crucial 8GBKIT (4GBx2) 240PIN DDR2 PC2-5300 ECC
Quicklinx: 4Q94WS00 Mfr#: CT2KIT51272AB667
Type: DDR2 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 667MHz
Data Integrity: ECC
£156.70 ex VAT
£188.04 inc VAT
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast. Each 240-pin DIMM provides a 64-bit data path.
To use DDR2 memory, your system motherboard must have 240-pin DIMM slots and a DDR2-enabled chipset. A DDR2 SDRAM DIMM will not fit into a standard SDRAM DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins. The notch in a 240-pin DDR2 DIMM is closer toward the center of the module.
Crucial - DDR2 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
667 MHz ( PC2-5300 )
Latency Timings
CL5
Registered
Voltage
1.8 V
Lead Plating
Gold
Sun X8098A, Sun X6322A, Sun X8124A-Z, Sun X4227A-Z, HP 408854-B21, Sun X5289A-Z, HP AD345A, Sun X4293A, DELL A2257191, Kingston KTH-BL860K2/8G, Kingston KTS4225K2/8G, Kingston KTS5093K2/8G, Kingston KTS5287K2/8G, Kingston KTS8122K2/8G, Kingston KVR400D2D4R3K2/8G, Kingston KVR533D2D4R4K2/8G, Kingston KVR667D2D4P5K2/8G, Kingston KVR667D2D8P5K2/8G, Kingston KVR667D2Q8P5K2/8G, Kingston KVR667D2S4P5K2/8G, Sun X5095A-Z, DELL A2257195, Sun X4063A-Z, Sun X4087A, DELL A2257196
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL5
ECC
Registered
Module Configuration
512 x 72
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 8GB
Speed: 667MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL5
Standard: PC2-5300
Brand: Crucial
Price Range Ex VAT: 150 - 300
