Product
Crucial 8GB Kit (4GBx2) DDR2 667MHz (PC2-5300) CL5 Unbuff UDIMM 240P
Quicklinx: 7J8VWS00 Mfr#: CT2KIT51264AA667
Type: DDR2 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 667MHz
Data Integrity: Non-ECC
£181.10 ex VAT
£217.32 inc VAT
8GB Kit (4GBx2), 240-pin DIMM, DDR2 PC2-5300 memory module
  • Part Number: CT2KIT51264AA667
  • Module Size: 8GB Kit (4GBx2)
  • Package: 240-pin DIMM
  • Feature: DDR2 PC2-5300
  • Specs: DDR2 PC2-5300 - CL=5 - Unbuffered - NON-ECC - DDR2-667 - 1.8V - 512Meg x 64
Crucial - DDR2 - 8 GB: 2 x 4 GB - DIMM 240-pin - unbuffered
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
IBM 8234, Sun X4204A, Sun SESX2C1Z, Kingston KTM-JS22K2/8G, Kingston KVR667D2N5K2/8G, Sun SESY2C1Z, Kingston KTS-SESK2/8G
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
512 x 64
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 8GB
Speed: 667MHz
Registered/Buffered: Unbuffered
CAS Latency: CL5
CAS Latency: CL5
Standard: PC2-5300
Brand: Crucial
Price Range Ex VAT: 150 - 300
