Crucial 8GB DDR4 PC4-21300 2666MHz CL19 ECC Reg. 1.2V RDIMM
Quicklinx: D9HSWS00 Mfr#: CT8G4RFS8266
Marketing description is not available.
  • Increase the performance of your servers
    Buying new servers is expensive. Getting more out of your current infrastructure isn't. Maximizing a server's installed memory capacity with Crucial RDIMMs is one of the easiest and most affordable ways to make your deployments faster and more efficient. Crucial RDIMMs contain a register chip, which directs data commands and helps control the flow of data within the server. By virtue of the register chip, Crucial RDIMMs have ECC parity, which helps prevent data errors and increases overall system reliability.
  • Speed up server applications
    By installing Crucial RDIMMs, you'll be able to maximize the performance capability of your CPUs and optimize your servers' computing potential. Since memory typically functions as a fixed (non-shared) component, it's often a bigger performance constraint than processors or storage drives, which can be shared. Maximize your investment in server infrastructure by maximizing memory capacity.
  • Get more out of your IT budget
    At a fraction of the cost of new servers, Crucial RDIMMs allow you to extend the life and performance of your existing infrastructure and get more out of the rack space you already have. Even if you need to replace existing deployments, you can still save by buying servers with the least amount of preinstalled memory, then maximizing the installed memory capacity with Crucial RDIMMs.
  • Compatible with OEM servers and warranties
    Similar to how you can upgrade a server's preinstalled components and choose whichever brands you want, you can do the same with memory - without having to worry about voiding your manufacturer's warranty. In terms of system compatibility, Crucial RDIMMs are optimized for the latest Intel Xeon processor product families and 100% component and module tested.
  • Run more virtual machines and increase the responsiveness of virtualized applications
    Since most of today's enterprise applications are stored on servers and distributed to a number of virtual machines, the amount of installed server memory plays a more critical role than ever before. Every virtual machine running on a server typically requires a dedicated amount of memory, meaning the more virtual machines you're running, the more memory you'll need.
  • Available in the latest technology
    Built with new technology tailored for the latest Intel platforms, Crucial DDR4 RDIMMs allow you to increase system performance with memory speeds up to 2666 MT/s and densities up to 32GB. Increasing the installed memory capacity of each server with modules equipped with 8Gb-based components enables your systems to reach their full performance potential - especially without rank limitations.
Crucial - DDR4 - module - 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Single rank, registered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL19
ECC
Chips Organization
X8
Voltage
1.2 V
