Crucial 8GB DDR3 PC12800-1600MHz SoDimm Crucial Dual Voltage
Quicklinx: 8FVLWS00 Mfr#: CT102464BF160B
Type: DDR3L SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
48 in stock
£49.16 ex VAT
£58.99 inc VAT
Help your laptop perform at its best. Designed to help your laptop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your laptop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial laptop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module Crucial manufactures is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your laptop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR3L - 8 GB - SO-DIMM 204-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.35 V
Colour Category
Green
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Crucial
Price Range Ex VAT: 0 - 50
