There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Laptop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your laptop's multitasking capabilities.
Make everything on your computer faster
Memory is a component in your computer that allows for short-term data access. Since your system's moment-to-moment operations rely on short-term data access - loading applications, browsing the Web or editing a spreadsheet - the speed and amount of memory in your system plays a critical role. Load apps in seconds by increasing the speed of your memory and installing more of it. -
Multitask with ease
If you're like us, you use your computer to do lots of things at once. You might be editing a document, while also looking at pictures and browsing the Internet. This naturally leads to a performance problem: every app you're running requires memory and competes for a limited pool of resources. Overcome this by installing high-density modules in each memory slot for seamless multitasking. -
Extend battery life
One of the most important aspects of laptop performance is battery life. By upgrading your memory, you can potentially take advantage of lower voltage modules - and increase energy efficiency by up to 40% when using the latest memory technology. 1 What's more, by simply installing more memory, you'll reduce the number of times your system has to access the hard drive (paging). Less paging means tasks are done faster - using less battery power. -
Maximize the value of your system
At a fraction of the cost of a new system, a memory upgrade is one of the most affordable ways to increase performance. Get more out of your laptop by giving it the resources it needs to perform.
- Crucial - DDR2 - kit - 8 GB: 2 x 4 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL6
- Unbuffered
- Voltage
- 1.8 V
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Module Height (inch)
- 1.25
- Speed
- Latency Timings
- CL6
- Non-ECC
- Unbuffered
- Module Configuration
- 512 x 64
- Voltage
- 1.8 V
