Crucial 8GB (2x4GB) DDR3-1600 1.35V SODIMM Memory
Quicklinx: 8898WS00 Mfr#: CT2C4G3S160BMCEU
Mac systems can run even better with a memory upgrade from Crucial. Our Apple memory is certified, OEM-quality, and guaranteed compatible. It's also surprisingly affordable.
Mac users demand the best — and Crucial delivers.
Our reliability and quality make Crucial memory ideal for any Mac system upgrade. Easy to find, easy to buy, and easy to install, Crucial's Apple-compatible memory is rigorously tested and comes from a division of one of the largest DRAM manufacturers in the world.
A trusted name
With over a decade in the DRAM business, Crucial is a recognized name in memory products. We are price-competitive, high-quality, and reliable. And we back our products with industry-leading warranties and outstanding service and support.
Crucial Apple Memory offerings:
  • DDR, DDR2 and DDR3 options
  • Certified FBDIMM modules
  • Legacy memory for older systems
Crucial - DDR3 - kit - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 / 1.5 V
8 GB: 2 x 4 GB
Upgrade Type
System specific
DRAM memory kit
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Voltage
1.35 / 1.5 V
Compatible Slots
2 x memory - SO-DIMM 204-pin
