Crucial 4GBKIT (2 x 2GB) 240-Pin DDR2 667MHz PC2-5300 NON ECC CL5
Quicklinx: 4Q84WS00 Mfr#: CT2KIT25664AA667
Type: DDR2 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 667MHz
Data Integrity: Non-ECC
£45.23 ex VAT
£54.27 inc VAT
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Crucial - DDR2 - 4 GB: 2 x 2 GB - DIMM 240-pin - unbuffered
RAM memory
4 GB: 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Sun SESX2B3Z, Sun T6340-X-22, IBM 8233, Sun SESX2B2Z, Sun X4203AF, Sun X5279A-Z, Sun SESX2B1Z, Kingston KTA-G5533/4G, Kingston KTM-JS22K2/4G, Kingston KTS-SESK2/4G, Kingston KTS-SESVK2/4G, Kingston KTS5277K2/4G, Kingston KVR400D2N3K2/4G, Kingston KVR667D2N5K2/4G, Apple MA248G/A
Intel Desktop Board D955XBK
4 GB: 2 x 2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 4GB
Speed: 667MHz
Registered/Buffered: Unbuffered
CAS Latency: CL5
CAS Latency: CL5
Standard: PC2-5300
Brand: Crucial
Price Range Ex VAT: 0 - 50
