Your basket is empty
Crucial 4GB kit (2x2GB) DDR2-1066 CL7 NonECC PC2-8500 (CT2KIT25664AA1067)
Quicklinx: 646GWS00 Mfr#: CT2KIT25664AA1067
Type: DDR2 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1066MHz
Data Integrity: Non-ECC
6 in stock
£52.42 ex VAT
£62.90 inc VAT
Standard delivery Delivered within 3-5 working days
Crucial - DDR2 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz ( PC2-8500 )
Latency Timings
CL7
Unbuffered
Voltage
1.8 V
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL7
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
Crucial 4GB kit (2x2GB) DDR2-1066 CL7 NonECC PC2-8500 (CT2KIT25664AA1067) Bundle deal on Crucial 4GB kit (2x2GB) DDR2-1066 CL7 NonECC PC2-8500 (CT2KIT25664AA1067)
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.02 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £3.50 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.00 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £2.99 | in stock
£68.73
saving £7.84
Type: DDR2 SDRAM
Capacity: 4GB
Speed: 1066MHz
Registered/Buffered: Unbuffered
CAS Latency: CL7
Standard: PC2-8500
Brand: Crucial
Price Range Ex VAT: 50 - 100
