More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
This product is a 4GB DDR4 server module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Registerred DIMM (RDIMM) with Error Correction Code (ECC). It conforms to the industry standard DDR4 RDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s RDIMM memory.
Faster speed
Process data faster. Enable higher responsiveness, and increase memory bandwidth. With Crucial memory, introductory data rates get even faster as the technology matures. Crucial memory also delivers faster burst access speeds for improved sequential data throughput by utilizing 4-bank groups. -
Large capacity
Maximize system performance by doubling memory capacity. As memory technology matures, it will allow you to double your server's memory capacity and get more out of every module - and your entire network. Built, using smaller die, that allow more Gigabits per component, Crucial memory is designed to utilize higher density components to deliver modules, that are much more dense. -
More energy efficient
Reduce power and cooling expenses. Crucial memory uses less voltage technology, and operates at lower power. Combined with the additional power-saving features inherent in memory architecture, Crucial memory is able to deliver significant power savings. Also, since less heat is generated per module, it's easier to keep systems cool.
- Crucial - DDR4 - module - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Single rank, registered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Chips Organization
- X8
- Voltage
- 1.2 V
- Colour Category
- Black, green
