Crucial 4GB DDR2 667MHZ PC2-5300
Quicklinx: 9J83WS00 Mfr#: CT51272AV667
Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
Crucial - DDR2 - module - 4 GB - DIMM 240-pin - 667 MHz / PC2-5300 - registered
Memory module
4 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Dual rank, registered
Voltage
1.8 V
Lead Plating
Gold
Crucial MT36HVS51272PY-667E1, Crucial MT36HVS51272PZ-667G1, Crucial MT36HVS51272PZ-667H1
4 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
Module Height (inch)
0.72
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
ECC
Module Configuration
512 x 72
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
RoHS
