Crucial 480GB BX200 2.5" 7mm (with 9.5mm adaptor) SATA 6Gb/s SSD
Quicklinx: BPG0WS00 Mfr#: CT480BX200SSD1
Crucial® BX200 Solid State Drive - Enjoy your computer again.
Ever start your computer, then have to find something to do while it wakes up? Your computer should be ready when you are – not the other way around. Make long wait times a thing of the past by loading apps in seconds, booting up almost instantly, and accelerating nearly everything on your computer. Get more done and have more fun with the Crucial® BX200 SSD.
More than 13x faster than a typical hard drive
Accessing your data on the Crucial BX200 is like flipping a light switch – it’s almost instant. The Crucial BX200 delivers true 540 MB/s sequential reads on both compressible and incompressible data, which allows you to access files and apps almost as soon as you click on them. Stop pulling your hair out waiting for your computer to catch up to you. Life moves fast – your computer should too.
More than 40x more energy efficient than a typical hard drive
Since SSDs access data on cutting-edge flash memory chips rather than on outdated spinning platters, they consume significantly less power than hard drives. Enjoy the ability to do more with longer battery life and experience a cooler, quieter system. Increase your laptop’s portability, worry less about finding an outlet, and boost your productivity.
More durable than a typical hard drive
Since SSDs don’t use moving parts that wear out over time, your photos, music, videos, and everything on the drive is less susceptible to a crash. Dropping a laptop with a hard drive may damage the small mechanical parts it uses to read and write data, and could cause the hard drive to fail. SSDs can sustain more physical trauma since they don’t rely on these mechanical parts.
Better value than a typical SSD
The Crucial BX200 leverages proven flash memory technology that’s been thoroughly vetted and engineered to extensive Micron quality standards. Upgrading to an SSD is one of the best ways to improve your system’s performance, and now the price per gigabyte makes it a great time to ditch your hard drive. Start getting more out of your storage.
PRODUCT HIGHLIGHTS
• Sequential reads/writes up to 540 / 490 MB/s on all file types
• Random reads/writes up to 66k / 78k IOPS on all file types
• More than 13x faster than a typical hard drive
• More than 40x more energy efficient than a typical hard drive
• More durable than a hard drive – no small moving parts that are prone to failure
• Available in 2.5-inch form factor in capacities up to 960GB
• Includes an activation key for Acronis® True Image™ HD software for easy data migration
• Compatible with the free Crucial® Storage Executive tool for easy drive monitoring and maintenance
• 3 year limited warranty
  • Do more, faster, longer
    The Crucial MX200 delivers 555 MB/s sequential reads on both compressible and incompressible data, and outperforms a typical hard drive by 400 MB/s. Even better, the performance doesn't let up, as the Crucial MX200 posts an endurance rating that's up to 5 times greater than a typical client SSD.
  • Transfer and save large files in a matter of seconds
    Competing SSDs typically rely on a fixed cache of multi-level cell flash memory, which allows you to write sequential data at published specs, but only for so long. The industry-leading Dynamic Write Acceleration technology solves this problem by using an adaptable pool of high speed, single-level cell flash memory for consistently fast performance that doesn't let up.
  • Max out performance and increase reliability
    The engineers created RAIN technology to protect your data at the component level, similar to how RAID is used with multiple hard drives. This technology increases the security and protection of your data to a level that's rarely seen in consumer-class SSDs.
  • hardware encryption
    Encrypt and protect your data at the highest possible level. Keep personal files and sensitive information secure from hackers and thieves with AES 256-bit encryption - the same grade used by banks and hospitals.
Crucial BX200 - SSD - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Thermal Monitoring System, TRIM support, Error Correction Code (ECC), DEVSLP SATA low power mode, Multistep Data Integrity Algorithm, Active Garbage Collection, Data Path Protection, S.M.A.R.T.
7 mm
Microsoft Certification
Compatible with Windows 7
3-year warranty
480 GB
2.5"
SATA 6Gb/s
7 mm
Performance
Internal Data Rate
540 MBps (read) / 490 MBps (write)
4KB Random Read
66000 IOPS
4KB Random Write
78000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
2.5mm mounting spacer
UL, TUV, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE, SATA-IO
Limited warranty - 3 years
70 °C
