Crucial 32GB Kit (4x8GB) DDR4 2133 MT/s (PC4-2133) CL15 SR x4 ECC Registered DIMM 288pin
Quicklinx: 9QPSWS00 Mfr#: CT4K8G4RFS4213
More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
This product is a 32GB Kit consisting (4) 8GB DDR4 server modules that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Registerred DIMM (RDIMM) with Error Correction Code (ECC). It conforms to the industry standard DDR4 RDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s RDIMM memory.
Crucial - DDR4 - kit - 32 GB: 4 x 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory kit
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Single rank, registered
Voltage
1.2 V
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Chips Organization
X4
Voltage
1.2 V
