Product
Brand
Crucial 32GB DDR4 2133 MT/s (PC4-2133) CL15 QR x4 Load Reduced DIMM 288pin
Quicklinx: B21CWS00 Mfr#: CT32G4LFQ4213
More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
CT32G4LFQ4213 is a 32GB DDR4 server module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Load-Reduce DIMM (LRDIMM) and conforms to the industry standard DDR4 LRDIMM layout of 288 pins. It is compatible with systems that take DDR4 2133MT/s LRDIMM memory.
Crucial - DDR4 - 32 GB - LRDIMM 288-pin
RAM memory
32 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Quad rank, sixteen banks, Load-Reduced
Voltage
1.2 V
32 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL15
ECC
Chips Organization
2048 x 4
Voltage
1.2 V
