Your basket is empty
Crucial 32GB (2x16GB) DDR4-2133 1.2V SO-DIMM Memory
Quicklinx: CBRDWS00 Mfr#: CT2K16G4SFD8213
Type: DDR4 SDRAM
Capacity: 32GB
Connection: SO-DIMM 260-pin
Speed: 2133MHz
Data Integrity: Non-ECC
£252.41 ex VAT
£302.89 inc VAT
More Energy Efficient
Extend battery life by using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 SODIMMs consume 20% less voltage than standard DDR3 technology. Crucial DDR4 SODIMMs also contain other efficiency features, for an overall power reduction of up to 40%
More Density
Pack more memory into your laptop than ever before. Crucial DDR4 SODIMMs debut in densities up to 8GB, and as DDR4 technology develops, modules are projected to hit 32GB?—?allowing you to install twice as much memory as you could in a DDR3 system. Since laptops only have 1-2 memory slots, high-density Crucial DDR4 SODIMMs allow you to overcome this limitation and install more memory for faster mobile performance.
More Speed
Load applications faster and run demanding programs without lag. Crucial DDR4 SODIMMs debut at 2133 MT/s?—more than 30% faster than DDR3 modules.
More Bandwidth
Effortlessly multitask between apps and empower your system to fire on all cylinders. Crucial DDR4 SODIMMs increase memory bandwidth by over 30%, allowing your system to handle more data at once. Crucial DDR4 SODIMMs are optimized for next-gen platforms, allowing you to maximize bandwidth.
Crucial - DDR4 - 32 GB: 2 x 16 GB - SO-DIMM 260-pin
RAM memory
32 GB: 2 x 16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
32 GB: 2 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
Non-ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
Crucial 32GB (2x16GB) DDR4-2133 1.2V SO-DIMM Memory Bundle deal on Crucial 32GB (2x16GB) DDR4-2133 1.2V SO-DIMM Memory
£265.90
saving £7.22
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-17000
Brand: Crucial
Price Range Ex VAT: 150 - 300
