Micron Technology is one of the world's leading providers of advanced semiconductor solutions. Micron's DRAM and Flash components are used in today's most advanced computing, networking, and communications products, including computers, workstations, servers, cell phones, wireless devices, digital cameras, and gaming systems. Micron's mission is to be the most efficient and innovative global provider of semiconductor solutions.
- Crucial - DDR2 - kit - 1 GB: 2 x 512 MB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory kit
- Capacity
- 1 GB: 2 x 512 MB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Unbuffered
- Voltage
- 1.8 V
- OEM Manufacturer Equivalent Part Number
- Kingston KTA-G5533/1G, Kingston KVR400D2N3K2/1G, Kingston KVR533D2N4K2/1G, Kingston KVR667D2N5K2/1G, Apple MA246G/A
- Limited lifetime warranty
- Designed For
- ABIT AA8XE
- Capacity
- 1 GB: 2 x 512 MB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL5
- Non-ECC
- Unbuffered
- Module Configuration
- 64 x 64
- Voltage
- 1.8 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Designed For
- ABIT AA8XE
Customer reviews
Write a review for the Crucial 2x512MB 240Pin DIMM PC2-5300 NonECC Unbuffered CL5 here!
Never had problems with crucial
Reviewed by Ross. Review Posted 23/04/2007
Despite the previous review I will be buying this memory with no concerns about reliability. I've bought Kingston and Crucial memory dozens of times, and have never had a single problem.
In 14 years I have never had to return either Kingston or Crucial memory. The previous reviewers symptoms are exactly those you get when memory has been damaged by static, and make me wonder if proper anti-static precautions were taken when installing the memory.
Memory chips are marked "static sensitive" for a reason. Shocks that you don't even feel yourself can completely fry parts of the chip, causing unpredictable crashes.
- Overall
- Ease of use
- Value for money
No Problems
Reviewed by Dave. Review Posted 04/11/2007
I have this in an ASRock Mother board (ConRoeXFire-eSATA2) and have had no problems with it at all and like the other reviewer, I have never had any trouble with Crucial memory.
- Overall
- Ease of use
- Value for money
Faulty Twice... Unlucky?
Reviewed by Stephen. Review Posted 26/06/2007
i bought this ram thinking it would give a goog boost to my pc. i though the recommended for vista was a extra assurance that it would be ok. i know i had the right type of ram but i still cant belive that i got this ram and the first lot was faulty and then i got my replacement and this was faulty aswell. i have now got a refund from dabs.com although its more to do with crucial than dabs and i am dissapointed with crucial.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
