Crucial 2GB (2x1GB) DDR2-667 1.8V SODIMM Memory
Customer rating: 5.0* (Write a review)
Quicklinx: 43J1WS00 Mfr#: CT2KIT12864AC667
A small outline dual inline memory module (SODIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). SODIMMs get their name because they are smaller and thinner than regular DIMMs. The gold pins on the bottom of the SODIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a SODIMM are not connected.
200-pin SODIMMs are used to provide DDR and DDR2 SDRAM memory for notebook computers. 200-pin SODIMMs are available in PC2700 DDR SDRAM, PC3200 DDR SDRAM, DDR2 PC2-6400 SDRAM, DDR2 PC2-5300 SDRAM, DDR2 PC2-4200 SDRAM and DDR2 PC2-3200 SDRAM. To use DDR or DDR2 memory, your system motherboard must have 200-pin SODIMM slots and a DDR- or DDR2-enabled chipset. A DDR or DDR2 SODIMM will not fit into a standard SDRAM SODIMM socket. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
The number of black components on a 200-pin SODIMM can vary, but it always has 100 pins on the front and 100 pins on the back, for a total of 200. 200-pin SODIMMs are approximately 2.625 inches long and 1.25 inches high, though the heights can vary. Like 144-pin SODIMMs, 200-pin SODIMMs have one small notch within the row of pins; however, the notch on the 200-pin SODIMMs is closer to the left side of the module.
CAS Latency
CL5
Registered/Buffered
Unbuffered
2
Product Line
Crucial
Standard
PC2-5300
Connection
200pin
Customer reviews
Write a review for the Crucial 2GB (2x1GB) DDR2-667 1.8V SODIMM Memory here!
Uber memory
Reviewed by Carlton. Review Posted 03/01/2008
Once again I must say well done Dabs on delivery. Got this memory to fit in my new laptop and I really have noticed the difference it has made to performance. Good value. Thanks
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Get Your Laptop Memory HERE!!!
Reviewed by Richard. Review Posted 28/10/2008
Ordered 2 x 1GB Laptop Memory from DABS on Wednesday 22nd October '08 and chose standard delivery. The memory arrived nicely within the target delivery time stated, nicely packaged up so no possibility of damage at all. Very easy to install, memory detected instantly without trouble. Now I can run Vista without it chugging like a tractor.....Thanks DABS - great service, great product.
  • Overall 5*
  • Ease of use 5*
I always buy Crucial
Reviewed by Anonymous Review Posted 15/02/2009
I always buy Crucial and this time dabs was the cheapest place to get it from. Full marks.
  • Overall 5*
  • Ease of use 5*
Read all 11 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
