Product
Crucial 2GB kit (1GBx2) DDR2 800MHz (PC2-6400) CL6 SODIMM 200pin
Quicklinx: 7J8YWS00 Mfr#: CT2KIT12864AC800
Type: DDR2 SDRAM
Capacity: 2GB
Connection: SO-DIMM 200-pin
Speed: 800MHz
Data Integrity: Non-ECC
£22.64 ex VAT
£27.16 inc VAT
A small outline dual inline memory module (SODIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). SODIMMs get their name because they are smaller and thinner than regular DIMMs. The gold pins on the bottom of the SODIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a SODIMM are not connected.
Crucial - DDR2 - 2 GB: 2 x 1 GB - SO-DIMM 200-pin - unbuffered
RAM memory
2 GB: 2 x 1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
DFI AM300-BF, CA230-BF, CT930-b, G5C100-N; Intel Desktop Board MGM45RM, MGM45WU; J&W MINIX-780G-SP128MB; MSI Fuzzy RS690T
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Module Height (inch)
1.25
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
2 x memory - SO-DIMM 200-pin
DFI AM300-BF, CA230-BF, CT930-b, G5C100-N , Intel Desktop Board MGM45RM, MGM45WU , J&W MINIX-780G-SP128MB , MSI Fuzzy RS690T
Type: DDR2 SDRAM
Capacity: 2GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL6
Standard: PC2-6400
Brand: Crucial
Price Range Ex VAT: 0 - 50
