Product
Crucial 2GB DDR2 800MHz (PC2-6400) CL6 Unbuffered ECC UDIMM
Quicklinx: 8KGYWS00 Mfr#: CT25672AA80EA
Type: DDR2 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 800MHz
Data Integrity: ECC
£50.30 ex VAT
£60.36 inc VAT
Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
Crucial - DDR2 - 2 GB - DIMM 240-pin - unbuffered
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
800 MHz (PC2-6400)
Latency Timings
CL5
ECC
Unbuffered
Module Configuration
256 x 72
Voltage
1.8 V
Compatible Slots
1 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 2GB
Speed: 800MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL5
CAS Latency: CL5
Standard: PC2-6400
Brand: Crucial
Price Range Ex VAT: 50 - 100
