Crucial 2GB 240PIN DDR2 PC2-5300 NON ECC
Quicklinx: 4Q6NWS00 Mfr#: CT25664AA667
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR2 - module - 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
Memory module
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
IBM 73P4973, IBM 30R5123, IBM 73P4985, IBM 41X4257, IBM 43R2002, HP PX977AT, IBM 30R5127, DELL A0735490, DELL A0743584, DELL A1229323, DELL A1249404, DELL A1371192, DELL A1763799, DELL A1763803, Crucial CT16HTF25664AY-667J3A, Kingston D25664E40, Kingston KTN-PM667/2G, Kingston KVR400D2N3/2G, Crucial MT16HTF25664AY-667E1, Crucial MT16HTF25664AY-667G1, Crucial MT16HTF25664AZ-667H1, HP PX977AA, HP 406363-888, DELL A0515351, Kingston KTM4982/2G, Kingston KVR667D2N5/2G, Kingston KTD-DM8400B/2G, Kingston KTH-XW4300/2G, Kingston KFJ2889/2G, Kingston D25664F50, Kingston KTA-IMAC533/2G, Kingston KTM3211/2G, Kingston KTD-DM8400A/2G, Kingston KTH-XW4200AN/2G, Kingston KFJ2888/2G, Kingston KVR533D2N4/2G
2 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.8 V
Compatible Slots
1 x memory - DIMM 240-pin
Colour Category
Green
