Product
Crucial 2GB (2 x 1GB) 240-pin DIMM DDR2 800MHz / PC2-6400 CL6 (CT2KIT12864AA800)
Quicklinx: 767QWS00 Mfr#: CT2KIT12864AA800
Type: DDR2 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 800MHz
Data Integrity: Non-ECC
£22.38 ex VAT
£26.85 inc VAT
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Crucial - DDR2 - 2 GB: 2 x 1 GB - DIMM 240-pin - unbuffered
RAM memory
2 GB: 2 x 1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
Voltage
1.8 V
DELL A0944600, DELL A0944559, DELL A0944553, DELL A3418659, DELL A3418660, DELL A3418661, DELL A3418662, DELL A3418664, DELL A3418665, DELL A0944556, DELL A0944563, DELL A0944567, DELL A0944578, DELL A0944589, DELL A0944591, DELL A0944604, DELL A0944605, DELL A1523761, Kingston KTD-PEM605/2G, Kingston KVR800D2N5K2/2G, Kingston KVR800D2N6K2/2G
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 2GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL6
Standard: PC2-6400
Brand: Crucial
Price Range Ex VAT: 0 - 50
