Crucial 250GB MX200 SATA 6GB/s 2.5" 7mm (with 9.5mm adapter) SSD
Quicklinx: B1V1WS00 Mfr#: CT250MX200SSD1
Crucial MX200 SSD - More speed, capacity, and endurance
Get more out of your storage.
When the Crucial® MX100 was released, it set a new standard for SSDs that the Crucial MX200 pushes even further. Leveraging leading specs on all fronts, along with new Dynamic Write Acceleration technology, the Crucial MX200 is loaded with innovative features and immediately increases your system’s performance.
Do more. Faster. Longer.
The Crucial MX200 delivers 555 MB/s sequential reads on both compressible and incompressible data, and outperforms a typical hard drive by 400 MB/s. Even better, the performance doesn’t let up, as the Crucial MX200 posts an endurance rating that’s up to 5 times greater than a typical client SSD.
Max out performance and increase reliability
Our engineers created RAIN technology to protect your data at the component level, similar to how RAID is used with multiple hard drives. This technology increases the security and protection of your data to a level that’s rarely seen in consumer-class SSDs.
Transfer and save large files in a matter of seconds.
Competing SSDs typically rely on a fixed cache of multi-level cell flash memory, which allows you to write sequential data at published specs, but only for so long. Our industry-leading Dynamic Write Acceleration technology solves this problem by using an adaptable pool of high speed, single-level cell flash memory for consistently fast performance that doesn’t let up.
Encrypt and protect your data at the highest possible level.
Keep personal files and sensitive information secure from hackers and thieves with AES 256-bit encryption – the same grade used by banks and hospitals. The Crucial MX200 meets or exceeds all industry encryption standards, including Microsoft® eDrive, IEEE-1667, and TCG Opal 2.0.
Run your system longer than ever before – using less power.
With Extreme Energy Efficiency technology, the Crucial MX200 is over 2x more energy efficient than a typical hard drive.
Push your drive to the limit and avoid overheating.
Adaptive Thermal Protection technology enables the Crucial MX200 to dynamically adjust storage component activity based on how you’re using the drive, allowing your storage system to stay cool.
Keep your memories, photos, and files safe.
When a photo or file gets corrupted, it often becomes unusable. Prevent this from happening in the first place with the Crucial MX200, which arms every storage component with four layers of Exclusive Data Defense.
  • Do more faster and longer
    The Crucial MX200 delivers 555 MB/s sequential reads on both compressible and incompressible data, and outperforms a typical hard drive. Even better, the performance doesn't let up, as the Crucial MX200 posts an endurance rating that's greater than a typical client SSD.
  • Transfer and save large files in a matter of seconds
    Competing SSDs typically rely on a fixed cache of multi-level cell flash memory, which allows you to write sequential data at published specs, but only for so long. The industry-leading Dynamic Write Acceleration technology solves this problem by using an adaptable pool of high speed, single-level cell flash memory for consistently fast performance that doesn't let up.
  • Max out performance and increase reliability
    The engineers created RAIN technology to protect your data at the component level, similar to how RAID is used with multiple hard drives. This technology increases the security and protection of your data to a level that's rarely seen in consumer-class SSDs.
  • Encrypt and protect your data at the highest possible level
    Keep personal files and sensitive information secure from hackers and thieves with AES 256-bit encryption - the same grade used by banks and hospitals. The Crucial MX200 meets or exceeds industry encryption standards, including Microsoft eDrive, IEEE-1667, and TCG Opal 2.0.
  • Efficiency & reliability
    Enjoy large amount of data and achieve a higher level of reliability than a hard drive or competing SSD.
  • Run your system longer than ever before - using less power
    With Extreme Energy Efficiency technology, the Crucial MX200 is more energy efficient than a typical hard drive.
  • Push your drive to the limit and avoid overheating
    Adaptive Thermal Protection technology enables the Crucial MX200 to dynamically adjust storage component activity based on how you're using the drive, allowing your storage system to stay cool.
  • Keep your memories, photos, and files safe
Crucial MX200 - SSD - 250 GB - SATA 6Gb/s
Solid state drive - internal
250 GB
Hardware Encryption
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Error Correction Code (ECC), Power Loss support, Adaptive Thermal Protection, Microsoft eDrive compatible, Redundant Array of Independent NAND, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, Exclusive Data Defense, S.M.A.R.T., 256-bit AES, IEEE 1667
7 mm
Microsoft Certification
Compatible with Windows 7
3-year warranty
250 GB
Hardware Encryption
2.5"
SATA 6Gb/s
7 mm
Performance
SSD Endurance
80 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
555 MBps (read) / 500 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
87000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Software Included
Acronis True Image HD
2.5mm mounting spacer
UL, TUV, VCCI, C-Tick, BSMI, IC, FCC, RoHS, KCC, WEEE
Limited warranty - 3 years
70 °C
