Your basket is empty
Crucial 1GB 240PIN DDR2 PC2-5300 ECC
Quicklinx: 4Q6XWS00 Mfr#: CT12872AA667
Type: DDR2 SDRAM
Capacity: 1GB
Connection: DIMM 240-pin
Speed: 667MHz
Data Integrity: ECC
£12.76 ex VAT
£15.31 inc VAT
Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
Crucial - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz ( PC2-5300 )
Latency Timings
CL4
Unbuffered
Voltage
1.8 V
HP DY652A, DELL A0428490, DELL A0515356, DELL A0515205, DELL A0515206, DELL A0515358, DELL A0690294, HP PV941ET, HP 384376-051, Crucial MT9HTF12872AZ-667H1, HP 398955-001, HP 384705-551, DELL A0504478, Kingston D12872E40, Kingston D12872F50, Kingston KTD-DM8400AE/1G, Kingston KTD-DM8400BE/1G, Kingston KTH-XW4200A/1G, Kingston KTH-XW4300E/1G, Kingston KVR400D2E3/1G, Kingston KVR533D2E4/2G, Kingston KVR667D2E5/1G, Kingston KVR667D2E5/1GI, Crucial MT18HTF12872AY-667F1, Crucial MT9HTF12872AY-667E1, Crucial MT9HTF12872AY-667G1, Crucial MT9HTF12872AZ-667G1, HP 390824-B21, HP 432804-B21, HP PV941A
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL4
ECC
Unbuffered
Module Configuration
128 x 72
Voltage
1.8 V
Compatible Slots
1 x memory - DIMM 240-pin
Type: DDR2 SDRAM
Capacity: 1GB
Speed: 667MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL4
Standard: PC2-5300
Brand: Crucial
Price Range Ex VAT: 0 - 50
