Product
Crucial 1GB 200pin SODIMM PC2700 DDRRAM Non-Parity
Customer rating: 5.0* (Write a review)
Quicklinx: 31BBWS00 Mfr#: CT12864X335
Type: DDR SDRAM
Capacity: 1GB
Connection: SO-DIMM 200-pin
Speed: 333MHz
Data Integrity: Non-ECC
£24.44 ex VAT
£29.32 inc VAT
Help your laptop perform at its best. Designed to help your laptop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your laptop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial laptop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module Crucial manufactures is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your laptop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - 1 GB - SO-DIMM 200-pin - unbuffered
RAM memory
1 GB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Unbuffered
Voltage
2.5 V
IBM 31P9834, IBM 31P9835, Gateway 5000735, DELL A0743537, HP DC890B, HP DC890A, HP 324702-001, HP 344868-001, Panasonic CF-WMBA401024B, HP 336579-001, HP 350238-001, HP 355927-001, HP 367775-001, Kingston KTT3311A/1G, DELL A0130832, IBM 10K0034, Fujitsu FPCEM101AP, Kingston KTT3614/1G, Toshiba PA3313U-1M1G, Acer LC.1GB01.001, DELL A0388055, HP 403800-001, Fujitsu FPCEM176AP, Fujitsu FPCEM118AP, DELL A0130829, HP EK693AA, HP DX763A, HP 383950-001, Kingston KTT3311/1G, Fujitsu FPCEM87AP, DELL A0743530, IBM 10K0035, DELL A0743507, DELL A0743508, DELL A0743509, DELL A0743528, DELL A0743529, DELL A0743531, DELL A0743532, DELL A0743533, DELL A0743534, DELL A0743535, DELL A0743536, DELL A0743538, DELL A0743539, DELL A0743540, DELL A0743541, DELL A0743542, DELL A0743543, DELL A0743544, DELL A0743545, DELL A0743546, DELL A0944594, DELL A1164151, DELL A1164155, DELL A1164356, Panasonic CF-BA511024, HP EK693AA#AC3, Kingston KAC-MEMC/1G, Kingston KFJ-FPC50/1G, Kingston KTA-PBG4333/1G, Kingston KTC-P2800/1G, Kingston KTD-INSP5150/1G, Kingston KTD-INSP8200/1G, Kingston KTH-ZD7000/1G, Kingston KTM-TP0028/1G, Kingston KTM-TP9828/1G, Kingston KVR266X64SC25/1G, Kingston KVR333X64SC25/1G, Kingston M12864B250, Kingston M12864C250, Crucial MT16VDDF12864HY-335F2, NEC N8002-54, Fujitsu S26391-F2594-E300, Fujitsu S26391-F2594-L300, DELL A0461912, DELL A0717895, HP 314114-B25, HP 339099-001, Toshiba PA3278U-1M1G, Kingston KFJ-FPC101/1G
1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
SO-DIMM 200-pin
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.5 V
Compatible Slots
1 x memory - SO-DIMM 200-pin
Customer reviews
Write a review for the Crucial 1GB 200pin SODIMM PC2700 DDRRAM Non-Parity here!
Cruical 1GB 200pin SODIMM PC2700
Reviewed by Anonymous Review Posted 21/12/2005
I fitted the Cruical 1GB 200pin SODIMM PC2700 to my TOSHIBA Satellite S2450-201,which had the standard 256mb PC2100 ram installed,the new ram works a treat,and it was a lot cheaper from DABS than from Cruical direct
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent Product!
Reviewed by Anonymous Review Posted 30/03/2006
I recieved this item within 5 days of ordering it and it come in great condition, thnaks Dabs! The product was easy to fit into my Toshiba Satellite Pro A60, with myself only requiring to slot it in and clip it down. My laptop now has much needed speed as a result of this. Also it cheaper to order it from here rather than directly from Crucial which is another of many good points about this product.
  • Overall 5*
  • Ease of use 5*
Best Memory ever
Reviewed by Anonymous Review Posted 26/03/2007
This is the best memory I've ever bought, and also the cheapest in its league. I bought it twice. The first time it was over £90, but still the cheapest. The second time, the price drops to just over £55, but with no availibility, and means I had to wait for 1-2 weeks. Unexpectedly, after several days (2-3 days), it was sent. Best service from dabs
  • Overall 5*
  • Ease of use 5*
Read all 12 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: DDR SDRAM
Capacity: 1GB
Speed: 333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL2.5
Standard: PC2700
Brand: Crucial
Price Range Ex VAT: 0 - 50
