Product
Crucial 1GB 200-pin SODIMM DDR2 PC2-6400
Quicklinx: 5F4ZWS00 Mfr#: CT12864AC800
Type: DDR2 SDRAM
Capacity: 1GB
Connection: SO-DIMM 200-pin
Speed: 800MHz
Data Integrity: Non-ECC
£11.03 ex VAT
£13.23 inc VAT
A small outline dual inline memory module (SODIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). SODIMMs get their name because they are smaller and thinner than regular DIMMs. The gold pins on the bottom of the SODIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a SODIMM are not connected.
200-pin SODIMMs are used to provide DDR and DDR2 SDRAM memory for notebook computers. 200-pin SODIMMs are available in PC2700 DDR SDRAM, PC3200 DDR SDRAM, DDR2 PC2-6400 SDRAM, DDR2 PC2-5300 SDRAM, DDR2 PC2-4200 SDRAM and DDR2 PC2-3200 SDRAM. To use DDR or DDR2 memory, your system motherboard must have 200-pin SODIMM slots and a DDR- or DDR2-enabled chipset. A DDR or DDR2 SODIMM will not fit into a standard SDRAM SODIMM socket. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
The number of black components on a 200-pin SODIMM can vary, but it always has 100 pins on the front and 100 pins on the back, for a total of 200. 200-pin SODIMMs are approximately 2.625 inches long and 1.25 inches high, though the heights can vary. Like 144-pin SODIMMs, 200-pin SODIMMs have one small notch within the row of pins; however, the notch on the 200-pin SODIMMs is closer to the left side of the module.
Crucial - DDR2 - 1 GB - SO-DIMM 200-pin - unbuffered
RAM memory
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
Voltage
1.8 V
DFI AM300-BF, CA230-BF, CT930-b, G5C100-N; Intel Desktop Board MGM45RM, MGM45WU; J&W MINIX-780G-SP128MB; MSI Fuzzy RS690T
1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Module Height (inch)
1.25
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Compatible Slots
1 x memory - SO-DIMM 200-pin
DFI AM300-BF, CA230-BF, CT930-b, G5C100-N , Intel Desktop Board MGM45RM, MGM45WU , J&W MINIX-780G-SP128MB , MSI Fuzzy RS690T
Type: DDR2 SDRAM
Capacity: 1GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL6
Standard: PC2-6400
Brand: Crucial
Price Range Ex VAT: 0 - 50
