Product
Crucial 1GB 184pin DIMM PC2700 DDRRAM NP Unbuffered CL2.5
Customer rating: 5.0* (Write a review)
Quicklinx: 319XWS00 Mfr#: CT12864Z335
Type: DDR SDRAM
Capacity: 1GB
Connection: DIMM 184-PIN
Speed: 333MHz
Data Integrity: Non-ECC
£22.04 ex VAT
£26.44 inc VAT
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - 1 GB - DIMM 184-PIN - unbuffered
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Unbuffered
Voltage
2.5 V
Lead Plating
Gold
DELL 311-2077, HP DC341A, IBM 33L3308, IBM 31P8857, HP 282436-B21, IBM 33L3309, HP DC166A, DELL 311-2364, Acer 77.11128.464, IBM 31P9123, DELL A0388038, HP 314794-001, HP 286403-001, IBM 40R0544, Kingston D12864B250, Kingston D12864C250, Kingston KFJ-CEL266/1G, Kingston KFJ2813/1G, Kingston KTA-G4333/1G, Kingston KTC-D320/1G, Kingston KTC-PR266/1G, Kingston KTD4400/1G, Kingston KTD4550/1G, Kingston KTM3304/1G, Kingston KTM8854/1G, Kingston KVR266X64C2/1G, Kingston KVR266X64C25/1G, Kingston KVR333X64C25/1G, Crucial MT16VDDF12864AY-335F1, Crucial MT16VDDT12864AY-335F2, Fujitsu S26361-F2813-E231, Fujitsu S26361-F2813-L231
Gigabyte GA-8IPE1000-G
1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Module Height (inch)
1.25
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 184-PIN
Customer reviews
Write a review for the Crucial 1GB 184pin DIMM PC2700 DDRRAM NP Unbuffered CL2.5 here!
Excellent
Reviewed by Anonymous Review Posted 11/12/2005
Did buy another ... great product, usual excellent Dabs service.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent
  • Overall 5*
  • Ease of use 5*
memory 1gb
Reviewed by teabellly. Review Posted 12/04/2007
Thanks dabs worked like a dream as usual Thanks again
  • Overall 5*
  • Ease of use 5*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: DDR SDRAM
Capacity: 1GB
Speed: 333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL2.5
Standard: PC2700
Brand: Crucial
Price Range Ex VAT: 0 - 50
