Product
Crucial 16GB DDR4 2133 MT/s (PC4-2133) CL15 DR x4 ECC Registered DIMM 288pin
Quicklinx: 9QPGWS00 Mfr#: CT16G4RFD4213
More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
This product is a 16GB DDR4 server module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Registerred DIMM (RDIMM) with Error Correction Code (ECC). It conforms to the industry standard DDR4 RDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s RDIMM memory.
  • Faster speed
    Process data faster. Enable higher responsiveness, and increase memory bandwidth. With Crucial memory, introductory data rates get even faster as the technology matures. Crucial memory also delivers faster burst access speeds for improved sequential data throughput by utilizing 4-bank groups.
  • Large capacity
    Maximize system performance by doubling memory capacity. As memory technology matures, it will allow you to double your server's memory capacity and get more out of every module - and your entire network. Built, using smaller die, that allow more Gigabits per component, Crucial memory is designed to utilize higher density components to deliver modules, that are much more dense.
  • More energy efficient
    Reduce power and cooling expenses. Crucial memory uses less voltage technology, and operates at lower power. Combined with the additional power-saving features inherent in memory architecture, Crucial memory is able to deliver significant power savings. Also, since less heat is generated per module, it's easier to keep systems cool.
Crucial - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, registered
Voltage
1.2 V
16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.2 V
Colour Category
Black, green
