Process data faster, reduce power expenses and minimize your TCO. It all starts with optimizing speed, efficiency, and your IT budget with Crucial DDR4 server memory.
Maximize channel density
Higher density components enable higher density modules, which offer increased performance. This makes it easy to scale up in the future as dependence on server applications increases through expanded virtualization, OLTP, Big Data, in-memory databases, and more - all of which rely on memory density and performance. -
Increase energy efficiency and minimize your TCO
Higher-density modules provide more value per gigabit and are also more energy efficient. The increase in density and value contribute to a marked improvement in total cost of ownership.
- Crucial - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17
- Dual rank, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 16 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Latency Timings
- CL17
- ECC
- Module Configuration
- 2048 x 72
- Chips Organization
- X8
- Voltage
- 1.2 V
