Your basket is empty
Crucial 16GB (2x8GB) DDR2-667 1.8V RDIMM Memory
Quicklinx: 7JB3WS00 Mfr#: CT2KIT102472AB667
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.)
Standard DDR2 240-pin DIMMs are available in DDR2 PC2-3200 SDRAM, DDR2 PC2-4200 SDRAM, DDR2 PC2-5300 SDRAM, and PC2-6400 SDRAM.
To use DDR2 memory, your system motherboard must have 240-pin DIMM slots and a DDR2-enabled chipset. A DDR2 SDRAM DIMM will not fit into a standard SDRAM DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins. The notch in a 240-pin DDR2 DIMM is closer toward the center of the module.
Crucial - DDR2 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
667 MHz ( PC2-5300 )
Latency Timings
CL5
Registered
Voltage
1.8 V
DELL A2257199, HP EV285AA, HP 408855-B21, DELL A2257200, DELL A2257238, DELL A2257239, DELL A2257240, DELL A3108767, DELL A3108769, DELL A3108770, Kingston KTH-XW9400K2/16G, Kingston KTS5287K2/16G, Kingston KTS8122K2/16G, Kingston KVR667D2D4P5K2/16G, Sun X8356A, Sun X4287A, Kingston KTD-PE6950/16G
SUPERMICRO X7DCA-3, X7DCA-i, X7DCA-L, X7DCL-3, X7DCL-i, X7DCT, X7DCT-10G, X7DCU; Tyan Tempest i5100W S5376G2NR, S5376WAG2NR
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL5
ECC
Registered
Module Configuration
1024 X 72
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
SUPERMICRO X7DCA-3, X7DCA-i, X7DCA-L, X7DCL-3, X7DCL-i, X7DCT, X7DCT-10G, X7DCU , Tyan Tempest i5100W S5376G2NR, S5376WAG2NR
