Your basket is empty
Crucial 12GB (3x4GB) DDR3-1600 1.5V DIMM Memory
Quicklinx: 9J88WS00 Mfr#: CT3KIT51272BB160B
Type: DDR3 SDRAM
Capacity: 12GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
£95.68 ex VAT
£114.81 inc VAT
Crucial 240-pin DIMMs are used in DDR3 memory for desktop computers. DDR3 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.) Standard DDR3 240-pin DIMMs are currently available in PC3-8500 (DDR3 1066MHz) and PC3-10600 (DDR3 1333MHz) speeds. Additional speeds will be added as the technology becomes available.
To use DDR3 memory, your system motherboard must have 240-pin DIMM slots and a DDR3-enabled chipset. This is because a DDR3 SDRAM DIMM will not fit into a standard DDR2 DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR3 DIMMS, 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins.
Crucial - DDR3 - 12 GB : 3 x 4 GB - DIMM 240-pin
RAM memory
12 GB : 3 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11
Dual rank , registered
Voltage
1.5 V
12 GB : 3 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Voltage
1.5 V
Compatible Slots
3 x memory - DIMM 240-pin
Crucial 12GB (3x4GB) DDR3-1600 1.5V DIMM Memory Bundle deal on Crucial 12GB (3x4GB) DDR3-1600 1.5V DIMM Memory
£111.69
saving £6.92
Type: DDR3 SDRAM
Capacity: 12GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL11
Standard: PC3-12800
Brand: Crucial
Price Range Ex VAT: 50 - 100
