The new Creative Woof3 Bluetooth speaker delivers sonic goodness in the size of a cup. Feel the action of your music rumble from the oversized bass radiator and hear your favorite musician's true potential come to life. Make Woof3 your perfect travel companion wherever you go.
Tiny companion that travels wherever you go
The Woof3 delivers big sound with bass you can feel. It neatly fits the palm of your hand and shaped like a compact cup that's easy to grab and go. In fact, this micro-sized Bluetooth MP3/FLAC speaker was designed with portability in mind - from the palm-sized form factor to the long battery life to the multiple connectivity options for audio playback. It is an all-in-one, full-featured Bluetooth MP3/FLAC speaker that's perfectly sized for life on the go. -
Palm-sized wonder
The Woof3 is equipped with a powerful 45mm driver that delivers well-balanced audio in your hand. Don't let its size fool you. This palm-sized wonder produces big sound for its size, thanks to the oversized bass radiator. With up to six hours of playtime on a single charge, you can roam free with the Woof3 everywhere! -
Plenty of ways to play your music
Connect with your favorite music with four input options. The Woof3 checks your list of essentials a portable speaker needs to have. -
Bluetooth connectivity
Pair your smart devices with the Woof3 via Bluetooth. Enjoy different levels of convenience with built-in music control buttons to play, pause, skip tracks and adjust the volume of your audio. -
Integrated MP3/FLAC player
The microSD slot makes a great playback option if you wish to conserve your smartphone's battery life. Simply insert a microSD card storing your favorite songs and press the play button to enjoy. Two music players in one microSD slot. Enjoy the best of both worlds from mainstream formats such as MP3/ WMA, to lossless high quality formats such as WAV/FLAC/APE - all neatly packed in one slot. Plus, it is a microSD card reader for transferring your music, video, and personal data between your microSD card and your computer. -
USB Audio
Connect the Woof3 to your PC/Mac with the included micro USB cable. It will function as a USB audio device that ensures lossless digital audio playback. Plus, you can charge the speaker simultaneously. -
AUX-in
Put an old school charm in the music you love. Connect your analog devices to the Woof3 using the 3.5mm AUX-in cable. -
A speakerphone in a speaker
With a built-in microphone, the Woof3 intelligently switches between your voice calls and music. So you won't have to miss another call again.
- Creative Woof 3 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Media Content Source
- USB-host, flash memory card
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, MP3, FLAC, APE (Monkey's Audio)
- Blue
- Built-in Decoders
- SBC decoder
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 6.5 cm x 6.8 cm x 7.5 cm
- 237 g
- Product Type
- Hands-Free Function
- Microphone
- Enclosure Colour
- Blue
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Built-in Decoders
- SBC decoder
- Audio Formats
- Controls
- Power on/off, volume, call answer, play/pause, next track, previous track
Speaker System Details
- Driver Details
- Speaker: full-range driver - 1.77" , Portable speaker: Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB to micro-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 500 mAh
- Run Time (Up To)
- 6 hour(s)
- 6.5 cm
- 6.8 cm
- 7.5 cm
- 237 g
