2.0 Wireless Speakers with NFC
Creative T30 Wireless builds on the technology of our GigaWorks T20 Series, featuring custom-made silk dome tweeters and woven glass-fiber cone drivers for excellent dynamic response, and BasXport® technology for high-output bass. It now comes with Bluetooth® capability and aptX® audio codec support to give you high-quality wireless playback and is further equipped with NFC for easy, one-touch pairing.
Tap and play
If your device has Near Field Communication (NFC) capabilities, simply tap it on the speakers' NFC receptor for easy, fuss-free pairing!
No more messy wires
Stream audio wirelessly from any compatible stereo Bluetooth smart device1 to the speakers from a range of up to 10 meters.
High-quality wireless audio
With the speakers' support for the aptX audio codec, you are set to enjoy high-resolution wireless Bluetooth audio that sounds as good as audio via a wired connection.
Primed for smooth highs and full-bodied midrange
Creative T30 Wireless features a 2-Driver Design - the custom-made silk dome tweeters give you silky smooth highs, while the woven glass-fibre cone drivers deliver natural and accurate full-bodied midrange. They work in tandem to produce an excellent dynamic response.
Get high-output bass
With the built-in BasXPort™ technology, each speaker is integrated with a large port tube to channel sound waves from the inner chamber of the satellite to the soundstage, giving you high-output bass.
Perfect anywhere
Creative T30 Wireless features an integrated line-in jack for connection to other analog audio devices, and a dedicated headphones jack for private listening. An RCA-to-3.5mm adapter is also included, giving you more connectivity options.
Tap and play
If your device has Near Field Communication (NFC) capabilities, simply tap it on the speakers' NFC receptor for easy, fuss-free pairing! -
No more messy wires
Stream audio wirelessly from any compatible stereo Bluetooth smart device to the speakers from a range of up to 10 meters. -
With the speakers' support for the aptX audio codec, you are set to enjoy high-resolution wireless Bluetooth audio that sounds as good as audio via a wired connection. -
Creative T30 Wireless features a 2-driver design - the custom-made silk dome tweeters give you silky smooth highs, while the woven glass-fiber cone drivers deliver natural and accurate full-bodied midrange. They work in tandem to produce an excellent dynamic response. -
With the built-in BasXPort technology, each speaker is integrated with a large port tube to channel sound waves from the inner chamber of the satellite to the soundstage, giving you high-output bass. -
Perfect anywhere
Creative T30 Wireless features an integrated line-in jack for connection to other analog audio devices, and a dedicated headphones jack for private listening. An RCA-to-3.5 mm adapter is also included, giving you more connectivity options. -
Face the music
Each of the speaker's face panel is tilted at a 10° angle for optimal audio projection directly at the listener. The Creative T30 Wireless is the perfect addition to any room.
- Creative T30 Wireless - speakers - wireless
- Product Type
- Speakers
- System Components
- 2 speakers
- Enclosure Design
- Bass reflex
- Speaker Type
- 2-way - active
- Amplifier
- Integrated
- Bluetooth, NFC
- Audio Formats
- Apt-X
- Speaker System Details
- 2 x speaker
- Gloss piano black
- Built-in Decoders
- SBC decoder, aptX
- 2-year warranty
- Product Type
- Speakers
- Enclosure Colour
- Gloss piano black
- Enclosure Design
- Bass reflex
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Amplifier
- Integrated
- Bluetooth 3.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Built-in Decoders
- SBC decoder, aptX
- Audio Formats
- Apt-X
- Controls
- Power on/off, volume, treble, bass
- Speakers Included
- 2 x speaker - 2-way
- Driver Details
- Speaker: mid-range driver - woven fibreglass , Speaker: tweeter driver - silk - Soft Dome
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Power adapter, audio adapter
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Left channel speaker: 8.7 cm x 17.5 cm x 23 cm / 850 g , Right channel speaker: 8.7 cm x 18 cm x 23 cm / 983 g
- Limited warranty - 2 years
