Thanks to the built-in SB-Axx1 audio processor of the Sound Blaster EVO Zx headset, you get vastly improved audio delivered to your ears in real-time. Be amazed by what you hear, even if it's from the most compressed sources.
Massively powerful
Get ready to unleash the full power and clarity of your audio. Sound Blaster EVO Zx's FullSpectrum 40 mm audio drivers are capable of reproducing the full audible range of the audio spectrum, so you won't miss a beat. -
Hear it, just the way you like it
Like your music punchy? More bass? Or want more immersive surround effects from your movies? Make these real-time playback adjustments by simply changing your audio settings with the Sound Blaster Central app, and then hear your audio come to life. -
High-fidelity audio streaming
With the headset supporting aptX and AAC technologies, you're assured that the audio content transmitted over Bluetooth is crystal clear. -
Shut out that noise
The headset's ear cups cover your ears entirely, passively cutting out external noise. So, whether you're on your skateboard or on the subway, what you hear is only the audio that matters most to you. -
Enjoy your headset even more
With the Sound Blaster EVO Zx, you can even experience cinematic, virtual 7.1 surround sound when you connect the headset to your PC or Mac! -
Clarity in voice communications
Communicate with confidence and be understood. The integrated dual beam forming microphones work in tandem with the headset's advanced CrystalVoice technologies to make sure you're always heard clearly. Ambient noise and echoes picked up by the microphones are reduced drastically. Likewise, unwanted noise from incoming calls is also being eliminated. CrystalVoice creates an acoustic zone that picks up only your voice and nothing else, so you can still be heard with amazing clarity in noisy environments. -
Voice commands, now more accurate
Remember the occasions when you tried in vain to instruct some voice-activated application to perform a task? With high-quality voice pickup and all the voice technologies packed into your headset, your commands can be transmitted accurately all the time. -
Tap and play, easy
Simply tap your Near Field Communications (NFC)-enabled device on the headset for easy, one-touch Bluetooth pairing. Sound Blaster EVO Zx supports up to two Bluetooth connections simultaneously, which is great if you're watching a movie on your tablet but wish to instantly switch to answer a call from another paired smart device. -
Connect in more ways than one
Besides Bluetooth pairing via NFC or the conventional way, you can also connect the headset to your PC or entertainment devices using the USB 2.0 connection, or the analog 3.5 mm jack. -
Up to 8 hours of playtime
Enjoy your music wherever you go as the built-in rechargeable battery has enough power for up to eight hours of continuous wireless audio playback. Low on power? Conveniently charge the headset via USB and continue to enjoy high-quality audio while doing so. -
Designed for easy storage, for your convenience
The headset can be folded to about 70% of its original size, and can be kept in the handy carrying pouch.
- Creative Sound Blaster EVO Zx - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 102 dB/mW
- Impedance
- 29 Ohm
- Product Type
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Foldable
- Wireless
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 102 dB/mW
- Impedance
- 29 Ohm
- Diaphragm
- 40 mm
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (4 PIN USB Type A) , Headset (mini-phone 3.5 mm 4-pole)
- Included Accessories
- Carrying case
- Cable Details
- USB cable - 1.8 m , Audio cable - 1.2 m
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 8 hour(s)
